Api session event editor panel apply template panels
Revision as of 10:19, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Apply Template Panels {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(PANEL Integer ID or multiple values in array [1, 2, 3]) |Panels | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorpanel/apply_template_panels/?f=HTML&token=API_TOKEN with content: <pre>[ [ 1,...")
0 REQUIRED (PANEL Integer ID or multiple values in array [1, 2, 3]) Panels
204 No Content
with content:
[ [ 1, 2, 3 ] ]
