Api session event editor netload generate paths
Revision as of 10:16, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Generate Paths {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(NET_FUNCTION Integer ID) |Net Functions | |- |1 |REQUIRED |(NET_LOAD Integer ID or multiple values in array [1, 2, 3]) |Net Loads | |- |2 |REQUIRED |(Floating point number) |Double | |- |3 |REQUIRED |(Floating point number) |Double | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ==...")
0 REQUIRED (NET_FUNCTION Integer ID) Net Functions
1 REQUIRED (NET_LOAD Integer ID or multiple values in array [1, 2, 3]) Net Loads
2 REQUIRED (Floating point number) Double
3 REQUIRED (Floating point number) Double
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetload/generate_paths/?f=HTML&token=API_TOKEN
with content:
[ 65, [ 1, 2, 3 ], 15, 38 ]
