Api session event editor netline remove repeated
Revision as of 10:15, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove the Net Lines, and optionally continue removing for Net Nodes that are connected the removed Net Line and that are only connected to one other Net Line of the same Net Type of the specified Net Line. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(NET_LINE Integer ID or multiple values in array [1, 2, 3]) |Net Line IDs | |- |1 |REQUIRED |(true, false) |Is repeated removal |true or false |} ===Response Cod...")
0 REQUIRED (NET_LINE Integer ID or multiple values in array [1, 2, 3]) Net Line IDs
1 REQUIRED (true, false) Is repeated removal true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetline/remove_repeated/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], true ]
