Api session event editor netline insert point
API Event to Insert a new Node in an existing Net Line, potentially splitting the Net Line into two parts. Also specify at what distance the new Nodes are merged with existing Nodes.
| 0 | REQUIRED | (NET_LINE Integer ID) | Net Line ID | |
| 1 | REQUIRED | (Point 3D with crs: EPSG:3857) | Inserted Node Point | |
| 2 | OPTIONAL | (Floating point number) | Node merge distance (optional, default: 1.0m) |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editornetline/insert_point/?crs=3857&f=HTML&token=API_TOKEN
with content:
[ 21, {
"type" : "Point",
"coordinates" : [ 658755.4504689976, 6799410.442364303, -1.88 ]
}, 1.0 ]
