Api session event editor measure import terrains
Revision as of 10:12, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Import Measure Terrain Collection {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(GeometryCollection with crs: EPSG:3857) |Collection of Terrain Geometries | |- |1 |REQUIRED |(Enumeration) |Measure Edit Type |BUILDING, FLATTEN, GEOTIFF, GRID, LEVEE, RAISE, UPGRADE or WATER |- |2 |REQUIRED |(Boolean or multiple values in array [true, false, true]) |Is Inner | |- |3 |REQUIRED |(TERRAIN_TYPE Integer ID or multi...")
0 REQUIRED (GeometryCollection with crs: EPSG:3857) Collection of Terrain Geometries
1 REQUIRED (Enumeration) Measure Edit Type BUILDING, FLATTEN, GEOTIFF, GRID, LEVEE, RAISE, UPGRADE or WATER
2 REQUIRED (Boolean or multiple values in array [true, false, true]) Is Inner
3 REQUIRED (TERRAIN_TYPE Integer ID or multiple values in array [1, 2, 3]) Terrain Type IDs
4 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Override Inner Heights
5 REQUIRED (Boolean or multiple values in array [true, false, true]) Height Relative
6 OPTIONAL (MEASURE Integer ID) Set for existing Measure ID (optional)
7 OPTIONAL (Floating point number) Buffer for Points and Lines to make Polygons (optional)
8 OPTIONAL (SOURCE Integer ID) Source (optional)
200 Integer (Measure ID)
Example POST: https://engine.tygron.com/api/session/event/editormeasure/import_terrains/?crs=3857&f=HTML&token=API_TOKEN
with content:
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799353.594913735 ], [ 658772.9294216395, 6799353.594913735 ], [ 658772.9294216395, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799406.971608278 ], [ 658759.1258889779, 6799406.971608278 ], [ 658759.1258889779, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799458.86906724 ], [ 658788.4058144778, 6799458.86906724 ], [ 658788.4058144778, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, "FLATTEN", [ true, false, true ], [ 1, 2, 3 ], [ 1.0, 2.0, 3.0 ], [ true, false, true ], "", "", "" ]
