Api session event editor measure add terrain polygons
Revision as of 10:11, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add polygons to existing outer (or inner) polygons of a Terrain Spatial of a Measure. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(MEASURE Integer ID) |Measure ID | |- |1 |REQUIRED |(Integer number) |Terrain Spatial ID | |- |2 |REQUIRED |(true, false) |Is Outer (false = inner) |true or false |- |3 |REQUIRED |(MultiPolygon with crs: EPSG:3857) |MultiPolygon | |} ===Response Codes=== {|class=wikitable !Resp...")
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (Integer number) Terrain Spatial ID
2 REQUIRED (true, false) Is Outer (false = inner) true or false
3 REQUIRED (MultiPolygon with crs: EPSG:3857) MultiPolygon
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/add_terrain_polygons/?crs=3857&f=HTML&token=API_TOKEN
with content:
[ 96, 76, false, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799425.6555646835 ], [ 658755.856503021, 6799425.6555646835 ], [ 658755.856503021, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
