Api session event editor indicator set parent
Revision as of 10:10, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set a parent Indicator for a specified Indicator. This will cause the specified Indicator to be a subselectable Indicator of the parent. It is not possible to set an Indicator which has a parent itself as a parent of another Indicator. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(INDICATOR Integer ID) |Indicator ID | |- |1 |REQUIRED |(Integer number) |Indicator ID of parent (indicators without a parent should h...")
0 REQUIRED (INDICATOR Integer ID) Indicator ID
1 REQUIRED (Integer number) Indicator ID of parent (indicators without a parent should have their parent Indicator ID set to -1)
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorindicator/set_parent/?f=HTML&token=API_TOKEN
with content:
[ 10, 45 ]
