Api session event editor geotiff add
Revision as of 10:08, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add new GeoTIFF Item with provided file. For files larger than 2GB, use the Stream API or Web URL. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(String) |GeoTIFF Name | |- |1 |REQUIRED |(byte or multiple values in array [a, b, c]) |File bytes (< 2GB) | |- |2 |REQUIRED |(String) |Uploader | |- |3 |OPTIONAL |(String) |CRS Override (optional) | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |In...")
0 REQUIRED (String) GeoTIFF Name
1 REQUIRED (byte or multiple values in array [a, b, c]) File bytes (< 2GB)
2 REQUIRED (String) Uploader
3 OPTIONAL (String) CRS Override (optional)
200 Integer (GeoTIFF ID)
Example POST: https://engine.tygron.com/api/session/event/editorgeotiff/add/?f=HTML&token=API_TOKEN
with content:
[ "GeoTIFF Name", [ 1, 2, 3 ], "Uploader", "" ]
