Api session event editor geoplugin set id attribute
Revision as of 10:08, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Id Attribute {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(GEO_PLUGIN Integer ID or multiple values in array [1, 2, 3]) |Geo Plugins | |- |1 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |String[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/edi...")
0 REQUIRED (GEO_PLUGIN Integer ID or multiple values in array [1, 2, 3]) Geo Plugins
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorgeoplugin/set_id_attribute/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]
