Api session event editor excelsheet export
Revision as of 10:06, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Export {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(EXCEL_SHEET Integer ID) |Excel Sheets | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |byte[] (byte array) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorexcelsheet/export/?f=HTML&token=API_TOKEN with content: <pre>[ 52 ] </pre> {{article end|seealso=*api session ev...")
API Event to Export
0 REQUIRED (EXCEL_SHEET Integer ID) Excel Sheets
200 byte[] (byte array)
with content:
[ 52 ]
