Api session event editor building generate water connection
Revision as of 10:04, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Generate Water Connection. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(FUNCTION Integer ID) |Function | |- |1 |REQUIRED |(MultiPolygon with crs: EPSG:3857) |Area | |- |2 |REQUIRED |(Floating point number) |Min Length | |- |3 |REQUIRED |(Floating point number) |Max Length | |- |4 |REQUIRED |(Floating point number) |Width | |- |5 |REQUIRED |(Floating point number) |Large Road Area | |- |6 |REQUIRED |(Floating po...")
0 REQUIRED (FUNCTION Integer ID) Function
1 REQUIRED (MultiPolygon with crs: EPSG:3857) Area
2 REQUIRED (Floating point number) Min Length
3 REQUIRED (Floating point number) Max Length
4 REQUIRED (Floating point number) Width
5 REQUIRED (Floating point number) Large Road Area
6 REQUIRED (Floating point number) Straight Distance
7 REQUIRED (Floating point number) Max Height Difference
8 REQUIRED (Floating point number) Ignore Upstream
9 REQUIRED (true, false) Include Water Bodies true or false
200 Integer (Amount of generated Objects)
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/generate_water_connection/?crs=3857&f=HTML&token=API_TOKEN
with content:
[ 11, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799458.860946561 ], [ 658718.1732973716, 6799458.860946561 ], [ 658718.1732973716, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, 44, 41, 53, 7, 49, 19, 12, false ]
