How to import 3D Models from ArcGIS Online
Revision as of 12:24, 10 March 2026 by Frank@tygron.nl (talk | contribs)
How to log in an ArcGIS Online account in the Tygron Client Application:
  1. Click on the Community tab and click on Sign in with ArcGIS
  2. In the new panel that pops up, choose Default ArcGIS Online and click on Continue to login
  3. Fill in your username and password
  4. Upon success, a confirmation message appears and the panel closes automatically.
  5. To add private or organizational data, see the instructions below.
How to import 3D Models from ArcGIS Online:
  1. Select Current Situation in the ribbon bar.
  2. Open the Geo Data Wizard and click next on the introduction step.
  3. Select the Buildings option in the Select Type step.
  4. Choose the Catalogue service option in the Import Method step.
  5. Choose the Select Catalogue service option with ArcGIS Online selected. (also to access the Enterprise portal data).
  6. In the Select Service step, click on the search option to browse through your Esri content , Esri organization content and Esri open data, available for this Project Area.
  7. In order to import 3D models, make sure to select a source of type Scene Service.
  8. In the Import from Layer step, optionally adjust the selected layer and click next to import the data.
  • If your organization uses a Custom ArcGIS Enterprise Portal, select that option in the ArcGIS Login panel. An additional access token is required for the Tygron Platform to communicate with ArcGIS. Such a token [1] can be created using ArcGIS Portal for your Enterprise.
  1. Arcgis Access Token ∙ Found at: https://developers.arcgis.com/documentation/security-and-authentication/reference/access-tokens/ ∙ (last visited: 09-03-2026)
