How to use a limit map in a Scenario
Revision as of 12:46, 21 October 2025 by Frank@tygron.nl (talk | contribs)
'"`UNIQ--youtube-00000000-QINU`"'
This howto uses the project Demo Heat Stress as a basis.
How to use a limit map in a Scenario:
  1. Select Current Situation in the ribbon bar
  2. Hover over Overlays, and under Administrative, select Scenario
  3. Activate the Scenario Overlay that was added to the Navigation Panel
  4. Click on the 'Go to 2D Map' button in the Navigation panel to zoom out to map view.
  5. Select Multi Scenario in the ribbon bar
  6. Select Scenarios in the ribbon bar
  7. Select the Scenario named 'Scenario'
  8. In the Scenario detail panel, adjust the Limit Calculation Scope to Measure Neighborhoods
  9. Set the Measure named Office Plan as a Triggered Measure.
  10. Select the Limit tab
  11. Notice the Margin set to 500 and the list of Neighborhoods containing all Neighborhoods.
  12. Inspect Scenario Overlay in the 3D visualization
  13. In the Scenario detail panel, Adjust the Margin to 0.
  14. Notice the list of neighborhoods reduced.
  15. Verify that the Scenario Overlay became smaller as well
  16. Select the general tab and adjust the limit scope to Neighborhoods.
  17. Select the limit tab and remove the first neighborhood.
  18. Verify that the Scenario Overlay became even smaller.
  19. Activate a test run by clicking on the play button and verify that the calculated overlays are limited as well, once the calculations have completed
