How to create a GeoShare Viewer
Revision as of 06:42, 18 July 2024 by Rudolf@tygron.nl (talk | contribs)
A GeoShare Viewer allows for the sharing of geographical data, most notably the results of calculations, via an easily sharable url without requiring the recipient to have an account for the Tygron Platform. Instead, the results are presented as a web viewer.
Editor → Current Situation (Ribbon tab) → Geo Import (Ribbon bar) → Geo Share (Dropdown)
How to create a GeoShare Viewer:
  1. In the Ribbon, click on the GeoShare link in the upper right.
  2. With the GeoShare opened, navigate to a folder that contains the data to be part of the viewer, such as GeoTIFFs or GeoJSONs.
  3. At the bottom of the GeoShare, click on "Add Viewer"
  4. In the prompt which appears, enter the desired name for the viewer
  5. In the next prompt, select the desired GeoTIFF(s)
  6. The viewer can now be opened by clicking on the link. The viewer will open in the web browser.
  7. The url of the web browser can be shared by copying it from the web browser's address bar.
Multiple timeframes
As can be seen from the first how-to, Grid Overlays with multiple timeframes are automatically recognized by the layer-add step of adding a GeoShare. This is recognized using the following naming convention: name-##.format. When uploading your own GeoTIFFs that represent multiple timeframes, take this naming convention into account before uploading them.
