How to upload files to the GeoShare
Revision as of 16:19, 30 January 2024 by Frank@tygron.nl (talk | contribs)
The GeoShare allows for centralized storage of geo data, which can easily be reused in multiple Projects by other Users. Data on the GeoShare can be browsed and imported on-demand, or can be automatically included in newly created Projects through Geoplugins.
How to upload a file to the Geo Share:
- Ensure the file is in a format which is compatible with the GeoShare.
- If the file should be uploaded to a directory which does not exist yet, at the bottom of the GeoShare window, opt to add a directory.
- If the file should be uploaded to a directory, click on the directory to open it, and repeat this process until the desired target directory has been reached.
- At the bottom of the GeoShare window, click on "Add Files".
- In the file selection window, select the file which should be added to the GeoShare.
- When the file upload has completed, the file is available on the GeoShare.
- For any given file, you can click the entry to open the file in a web browser. This way, the url of the file can be obtained.
- If the browser prompts a download of the file, accept the download, and then check the web browser's download history to obtain the url the file originated from.
