How to set linear evaporation rate (Water Overlay)
Revision as of 16:13, 30 January 2024 by Frank@tygron.nl (talk | contribs)
For a Water Overlay, evaporation rate is defined in Weather data.
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The Water Overlay (Left panel) → Configuration Wizard (Right panel)
How to set linear evaporation rate:
  1. Open the configuration wizard of the Water Overlay.
  2. Continue to the step concerning weathers.
  3. Select the weather event you wish to update, or select "Add" to create a new one.
  4. Set the "Surface evaporation" setting to "Linear".
  5. In the "Surface evaporation" field, set the desired evaporation rate.
  6. Close the wizard.
  • The evaporation rate is in mm/day, so for any given evaporation rate configured, the total amount of evaporation will be less as simulation time decreases.
