How to add an Attribute Action to your project
Revision as of 13:15, 30 January 2024 by Frank@tygron.nl (talk | contribs)
Adding Attribute Actions to a project
Attribute Actions can be added to you project. Attribute Actions can be found under the Future Design tab in the editor of the Tygron Platform.
EditorFuture Design (Ribbon tab) → Attributes (Ribbon bar) → Add Attribute Action (Dropdown menu)
How to add Attribute Actions to a project:
  1. In the editor, select the Future Design tab
  2. Select Attributes
  3. From the dropdown menu, select Add Attribute Action
  4. The new Attribute Action now appears in the Left Panel
How to add an Attribute Action to an Action Menu:
  2. Select Actions
  3. Add a new, or select an existing Action Menu on the Left Panel
  4. Select the Actions tab on the Right Panel
  5. Click on the Attribute Actions entry, and check the desired Attribute Action
  6. Now the newly added Attribute Action is available in the selected Action Menu
How to change Attribute Actions in a project
EditorFuture Design (Ribbon tab) → Attributes (Ribbon bar) → Show Attribute Actions (Dropdown menu) → Select Attribute Action to edit (Left Panel) → Adjust values of selected Attribute Action (Right Panel)
How to edit an Attribute Action or its values:
  3. Select the desired Attribute Action from the available Attribute Actions on the Left Panel
  4. On the Right Panel you can now edit the Attribute Action by changing, adding or removing attribute/ value pairs
