Bowen ratio (Function Value)
Revision as of 13:47, 26 January 2024 by Frank@tygron.nl (talk | contribs)
| Function value | Attribute | Unit | Per category | Range | Description |
| Bowen ratio | BOWEN_RATIO | ratio | 0.001 to 10 | The ratio between two forms of heat transfer between this building's surface and the atmosphere. |
Values
- The default values for this Function Value are based on values in the DPRA Heat stress report. Vegetation is set to a default of 0.4, and other values at 3.0.
- The default values are not overwritten during the creation of a new project.
Used for
- Heat stress Overlay (specifically DPRA Heat Module)
