Machine fuel usage (Aerius Overlay)
Revision as of 13:52, 3 November 2023 by Rudolf@tygron.nl (talk | contribs)
This functionality is deprecated and will be removed in the future.
This attribute defines the fuel usage in liter per year for the used building machine category. When multiple construction machine categories are chosen, this attribute should contain multuple fuel usages and becomes an array.
Example
We have the following fuel usages for the construction of building b:
  • 40 l / year for category: Stage-IV, 2014-2018, 56-75 kW, diesel, SCR: ja
  • 10 l / year for category: Stage-IIIA, 2006-2010, 56-75 kW, diesel, SCR: nee
First we have to map the categories to an index. According to the machine category table:
  • Stage-IV, 2014-2018, 56-75 kW, diesel, SCR: ja has index 18
  • Stage-IIIA, 2006-2010, 56-75 kW, diesel, SCR: nee has index 9
The attribute for the MACHINE_CONSTRUCTION_CATEGORY key for building b should then be set to: [18,9]
The attribute for the MACHINE_FUEL_USAGE key for building b should then be set to: [40,10]
