Machine operating hours (Aerius Overlay)
Revision as of 13:51, 3 November 2023 by Rudolf@tygron.nl (talk | contribs)
This functionality is deprecated and will be removed in the future.
This attribute defines the operating hours for the used building machine category. When multiple construction machine categories are chosen, this attribute should contain multiple operating hours and becomes an array.
Example
We have the following fuel usages for the construction of building b:
  • 400 hours for category: Stage-IV, 2014-2018, 56-75 kW, diesel, SCR: ja
  • 100 hours for category: Stage-IIIA, 2006-2010, 56-75 kW, diesel, SCR: nee
First we have to map the categories to an index. According to the machine category table:
  • Stage-IV, 2014-2018, 56-75 kW, diesel, SCR: ja has index 18
  • Stage-IIIA, 2006-2010, 56-75 kW, diesel, SCR: nee has index 9
The attribute for the MACHINE_CONSTRUCTION_CATEGORY key for building b should then be set to: [18,9]
The attribute for the MACHINE_OPERATING_HOURS key for building b should then be set to: [400,100]
