How to smooth Grid Overlay results
Revision as of 14:28, 30 August 2023 by Rudolf@tygron.nl (talk | contribs)
Some calculation results, although accurate and/or validated by expert parties, may present coarse results. A notable example is the Heat Overlay, which depending on the circumstances can create hard breaks in what would otherwise be expected to be relatively analog results. For some audiences or impressions, it is therefor desirable to smooth out the results somewhat, striking a balance between accuracy in numbers and in spatial sense.
To do this, an Average Overlay is used. This Average Overlay will present the actual results, while the original coarse results will remain available from the Grid Overlay which provided them.
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar)
Template:Editor steps
  • The greater the averaging distance, the smoother the results. However, the smoother the results, the less detailed the results will be.
