How to create an interest area GeoJSON
For some calculation models, often those found in Project Templates, the actual area of interest to consider results of does extent across the entire extent of a Project. Instead, only a specific polygon may be relevant. This polygon is known as Interest Area. While creating a new Project, it is also possible to use a file defining such an area to automatically select the appropriate location and extent for the new Project. However, this relies on having a GeoJSON file with such a definition before starting work on a Project.
These steps describe the process in QGIS, but similar steps in other GIS applications can yield the same result.
- Multiple discrete features may be present in a single Interest Area GeoJSON. Each feature will be loaded in as a separate Area.
- When using MultiPolygons, each feature consisting of multiple Polygons will be loaded in as a single Area with multiple polygons.
- Attributes of the features in the GeoJSON file will be ignored when using it during Project generation. Instead, a single INTEREST_AREA Attribute with a value of "1" will be added to all Areas added in this way.
- In The Netherlands, using Open Basis Kaart (https://www.openbasiskaart.nl/mapcache) as a WMS is a good way to obtain a background layer.
