How to add or remove or duplicate a Stakeholder
Revision as of 14:10, 21 October 2022 by Frank@tygron.nl (talk | contribs) (Created page with "{{Editor location|Stakeholders}} ===Adding stakeholders=== In the editor, new stakeholders can be added to your project in two ways: using the ribbon bar dropdown menu, or using the left panel ====Adding stakeholders using the ribbon bar dropdown menu==== 150px|thumb|left|The ribbon bar dropdown menu {{Editor steps|title=add a new stakeholder using the ribbon bar dropdown menu|Select "Multi stakeholder" in the ribbon header.|Select "Stak...")
Editor → Multi Scenario (Ribbon tab) → Stakeholders (Ribbon bar)
Adding stakeholders
Template:Editor steps
Adding stakeholders using the left panel
Removing and Duplicating stakeholders using the left panel
Template:Editor steps Template:Editor steps
