How to generate a network using the network wizard
Revision as of 13:46, 7 October 2022 by Frank@tygron.nl (talk | contribs) (Created page with "It is possible to let the {{software}} generate a network for you. This can be done using the Net wizard, which will guide you through the process. {{Editor location|Net Wizard}} Category:NetworkCategory:How-to")
It is possible to let the Tygron Platform generate a network for you. This can be done using the Net wizard, which will guide you through the process.
Editor → Current Situation (Ribbon tab) → Networks (Ribbon bar) → Network wizard (Dropdown)
