Prequels (Subsidence Overlay)
Revision as of 08:21, 11 February 2022 by Rudolf@tygron.nl (talk | contribs)
Prequel overlays can be linked to the Subsidence Overlay to initiate particular parts of the model with more accuracy and detail.
| Name | Prequel | Underlying data | Unit | Range | No data | Description |
| High ground water | HIGH_GROUND_WATER_LEVEL | Subsidence Prequel | m | The depth of the ground water level, relative to the surface | ||
| Low ground water | LOW_GROUND_WATER_LEVEL | Subsidence Prequel | m | The depth of the ground water level, relative to the surface | ||
| Clay thickness | CLAY_THICKNESS | Subsidence Prequel | m | The thickness of the clay layer on the peat, for the calculation of the oxidation component of Subsidence. |
