High ground water prequel (Subsidence Overlay)
Revision as of 16:42, 10 February 2022 by Frank@tygron.nl (talk | contribs)
| Name | Prequel | Description |
| High ground water level prequel | HIGH_GROUND_WATER_LEVEL | The depth of the ground water level, relative to the surface |
The initial high groundwater level in the Subsidence Module at the start of the simulation can be initialized using a prequel Grid Overlay. In the Subsidence Overlay Wizard it is possible to select one of the Default datasets provided, to import and create a GeoTIFF Overlay or to do nothing and proceed with the next step.
Default data
For the Netherlands, a number of groundwater GeoTIFFs are provided by default, based on data provided by The Netherlands Hydrological Instrumentarium:
- NL_GHG_kk-nhi (Average highest watertable)
- NL_GLG_kk-nhi (Average lowest watertable)
- NL_GVG_kk-nhi (Average spring watertable)
These GeoTIFFs can be linked to the Subsidence Overlay using a GeoTIFF Overlay and configuring this as the prequel to the High ground water level.
- Specified as m below terrain height
- When no prequel is specified, the water levels of groundwater level areas are used to initialize groundwater levels.
