Oxidation formula (Subsidence Overlay)
Revision as of 14:54, 9 February 2021 by Frank@tygron.nl (talk | contribs)
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle S_O = d_{gw,y} \cdot a_{y} - d_{ct} \cdot b - c}
where
  • is the subsidence due to oxidation.
  • is the calculated ground water depth for year y.
  • is the calculated a parameter value for the current year .
  • is the clay thickness of the terrain, defined by CLAY_THICKNESS
  • Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle b} is the b parameter value, defined by PARAMETER B
  • Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle c} is the c parameter value, defined by PARAMETER C
This formula was provided by experts, who have derived this formula empirically.
