Parameter a recalculation formula (Subsidence Overlay)
Revision as of 15:21, 8 February 2021 by Frank@tygron.nl (talk | contribs) (Created page with "The ''a'' parameter is recalculated yearly, to account for a changing climate. The new value for the ''a'' parameter is obtained by multiplying the original Parameter a (Sub...")
The a parameter is recalculated yearly, to account for a changing climate. The new value for the a parameter is obtained by multiplying the original Parameter a is with a factor. This factor is calculated based on an interpolated average temperature for that year, a soil temperature factor, micro activity and an oxidation factor.
The value of the a parameter is updated each year as follows:
Delta temperature is calculated as:
ΔT=(Tfinal−Tstart)⋅yy−ystartyfinal−ystart⋅fst
Delta micro activity is calculated as:
ΔMA=Q10ΔT/10.0−1.0
Delta subsidence is calculated as:
ΔS=ΔMA⋅fox
The new parameter a value for year y is calculated as:
ay=a0⋅(1+ΔS)
  • ay = The a parameter for the current year.
  • a0 = The defined a parameter to start the calculation with.
  • Ty = The interpolated average temperature for the calculation in the current year.
  • yy = The current year.
  • ystart = The start year of the simulation, defined by CLIMATE_START_YEAR.
  • yend = The final year of the simulation, defined by the addition of the start year and YEARS.
  • Tstart = The average temperature of the start year, defined by CLIMATE_START_TEMP.
  • Tfinal = The average temperature of the final year, defined by CLIMATE_FINAL_TEMP.
  • Q10 = The Q10 factor, configured as 3. This value is currently not adjustable
  • fst = Soil temperature factor, defined by CLIMATE_SOIL_TEMP_FACTOR.
  • fox = Oxidation factor, defined by CLIMATE_OXIDATION.
