Low Passive Drainage (Subsidence Overlay)
Revision as of 10:15, 19 November 2020 by Reijn@tygron.com (talk | contribs) (Reijn@tygron.com moved page LOW PASSIVE DRAINAGE to Low Passive Drainage (Subsidence Overlay))
| LOW_PASSIVE_DRAINAGE | m | When passive drainage is applied, the GLG (lowest ground water level) is increased by this amount. | -0 |
Due to definitions "Increase" means that the distance between the surface and this ground water level increases. The default value does not affect the ground water level.
