Low Passive Drainage (Subsidence Overlay)
Revision as of 15:33, 18 November 2020 by Reijn@tygron.com (talk | contribs) (Created page with "{{Overlay attributes|<onlyinclude> {{Overlay attributes|type=row|overlay=subsidence |attribute=LOW_PASSIVE_DRAINAGE |unit=T |description=When passive drainage is applied, the...")
LOW_PASSIVE_DRAINAGE T When passive drainage is applied, the GLG (lowest ground water level) is increased by this amount. 0}
Due to definitions "Increase" means that the distance between the surface and this ground water level increases. The default value does not affect the ground water level.
