Waterwijzer Module test results
Revision as of 09:59, 31 August 2020 by Rudolf@tygron.nl (talk | contribs)
Testing the Waterwijzer Module manually is feasible, as the performed calculations are not spatial. This means for any given location, only the parameters present in that particular location are used to perform a calculation.
Setting up the project
  • Create a new empty Project with a minimal size. By creating an empty project the state of the 3D world is entirely known.
  • Add the Waterwijzer overlay to the Project. This will perform the actual calculations.
Groundwater
The groundwater situation is easiest to set up by using a subsidence overlay. It needn't calculate, but can have its groundwater situation directly configured through Areas and Attributes so that it's set to a specific value.
Crops
Terrains
Configuring a testable dataset
Results
