How to add an Attribute
Revision as of 08:55, 12 June 2020 by Rudolf@tygron.nl (talk | contribs) (Rudolf@tygron.nl moved page How to add an attribute to How to add an Attribute without leaving a redirect)
The right panel allows you to add new attributes. The top half displays existing attributes, the bottom half allows you to add new attributes.
Many things in a Project, ranging from Stakeholders to Overlays to Constructions, have Attributes, allowing generic properties to be configured for them. For most kinds of data, Attributes can be added and edited in a similar fashion.
Editor → The type of data to edit (Ribbon bar) → The data to edit (Left panel) → Attributes tab (Right panel)
How to add an attribute:
  1. Select the type of data to add an Attribute to.
  2. Switch to the "Attributes" tab.
  3. Scroll to the bottom of the right panel, if neccesary
  4. For "Add new Attribute with name", enter the desired TQL name name.
  5. For "Add new Attribute with value", enter the desired value.
  6. Click on "Save new Attribute".
  7. The Attribute has now been added.
