How to change the Category of a Function
Revision as of 12:23, 11 June 2020 by Rudolf@tygron.nl (talk | contribs)
The Function Categories of Functions can be changed.
How to add an additional Category to a Function:
- If the Function you wish to add the Category to is not yet present in the list, add the Function to the list.
- Add the desired new Category to the Function.
- Remove the old Category from the Function.
- When a new Category is added to a Function, the Category Values of the new Category will be set to default values. If the new Category should have the same Category Values as the old Category, the values should copied over to the new Category before removing the old one.
- Some Categories can not be combined with any other Categories, prohibiting changing the Category of a Function to or from that Category.
