How to correct your Water Overlay data
When working with the Water Overlay, it is desirable to work directly with the source data available. However, there may be aspects of the data which conflict with the way the Water Overlay functions. These situations may require some corrections to have the data properly interpreted by the calculation model.
Depending on the situation, clear instructions to correct the issue may exist. However, due to the inherent complexity which may be involved with various combinations of data, for some situations only advice on how to investigate a potentially erroneous phenomenon can be offered.
Corrections
The following instructions are corrections to data which are otherwise nearly certain to function incorrectly.
Improvements
The following instructions are improvements which will allow the simulation to come to a more realistic result.
Investigations
The following instructions are general checklists for when certain odd results are produced by the simulation, to investigate whether (and if so where) an issue with the model exists.
