Weir formula (Water Overlay)
Revision as of 10:55, 20 March 2020 by Frank@tygron.nl (talk | contribs)
Flow across weirs is calculated differently for free flow and submerged flow.
The height of the water at each end of the weir, relative to the weir, is calculated:
- hs = max(0, max( wl, wr ) - zw)
- hd = max(0, min( wl, wr ) - zw)
- Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle h_{ratio} = h_d / h_s}
- Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle C = min ( C_{submerged} , C_{free})} if Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle h_{ratio} > 0,5}
- Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle C = C_{free} otherwise}
For free flow, capacity is calculated directly:
- Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle C_{free} = f_{w,d} \cdot c_w \cdot w_w \cdot ( h_s - h_d )^{3/2}}
For submerged flow, the following calculation is used:
- Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle C_{submerged} = U_{loss} \cdot A \cdot \sqrt{ 2 \cdot g \cdot ( h_s - h_d ) }}
- Δw = Δt * C / Δx
Where:
- hs = The height of the water column relative to the top of the weir, on the side with the highest water level.
- hd = The height of the water column relative to the top of the weir, on the side with the lowest water level.
- wl = The water level on the left side of the weir, relative to datum.
- wr = The water level on the right side of the weir, relative to datum.
- zw = The WEIR_HEIGHT of the weir.
- fw,d = Dutch weir factor, set to 1.7.
- cw = The WEIR_COEFFICIENT of the weir.
- ww = The WEIR_WIDTH of the weir.
- C = The potential rate of water flow across the weir.
- hratio = The ratio of water heights on either side of the culvert.
- Cfree = The potential rate of water flow across the weir, based on a free flow calculation.
- Csubmerged = The potential rate of water flow across the weir, based on a submerged calculation.
- Uloss = Loss coefficient for submerged weirs, set to 0.9.
- A = Flow area, based on the highest water column height relative to the top of the weir, and WEIR_WIDTH of the weir.
- g = Acceleration factor of GRAVITY, defined for the Water Overlay.
- Δw = The water flow which takes place.
- Δx = Cell size.
Related
- Structures
- Weir
- Models
- Surface model
