How to add a water limitation area
Revision as of 14:07, 14 February 2020 by Rudolf@tygron.nl (talk | contribs) (Rudolf@tygron.nl moved page How to add a limit area to How to add a limitation area without leaving a redirect)
Template:Editor steps
  • It is also possible to add a different attribute name for the limitation area, but with a value above 0. In that case, in the extra step in the wizard, choose for the option Select existing limitation areas based on attribute and select the custom attribute name of your limitation area.
  • It is also possible to import a limitation area. In that case, select in the extra step in the wizard the option Import limitation areas (start Geo data wizard) and proceed with the Geo data wizard.
