How to remove a WFS link from your project
Revision as of 10:43, 10 February 2020 by Rudolf@tygron.nl (talk | contribs)
WFS links you have added yourself can be removed from your project.
Editor → Current Situation (Ribbon tab) → Geo import (Ribbon bar) → Show Project Sources (Dropdown)
How to remove a WFS Connection:
  1. Select the desired connection you wish to remove
  2. Click on the button 'Remove' in the bottom left corner
  • The project sources created and used by the Tygron Platform cannot be removed.
  • An unused WFS link does not affect your data in any capacity, so removing them is not required. However, especially when working with multiple users in the same project, or when creating a template project, keeping the WFS links limited to valid and relevant options is recommended.
