UHI formula (Heat Overlay)
Revision as of 10:50, 17 December 2019 by Bobby@tygron.nl (talk | contribs)
The Urban heat island effect is calculated using the following formula:
Formula Decomposition
The formula has two parts, the factor and the temperature effect:
Factor
The factor is influenced by the sky view factor and the vegetation fraction, both ranging from 0 to 1. When both are low, i.e. barely any sky and no vegetation, the factor is near 2. When both are high, i.e. no surrounding buildings and a lot of vegetation, the factor is near 0. In that case, the resulting heat island effect will be low as well.
Temperature effect
The Urban heat island temperature effect is calculated as:
Daily average global radiation
The S is calculated as followed:
where,
  • is the daily average global radiation in W/m2/hr
  • is the air heat capacity in J. We use a value of 1007 J.
  • is the hourly temperature measured at the station
  • is the calculated air density in kg/m3;
  • is the gas constant for dry air. We use a value of 287.058 J/(kg·K)
