How to set linear evaporation rate (Water Overlay)
Revision as of 11:59, 12 June 2019 by Rudolf@tygron.nl (talk | contribs) (Created page with "For a Water Overlay, evaporation rate is defined in Weather) data. {{editor location|overlay wizard|The Water Overlay}} {{howto|title=set line...")
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The Water Overlay (Left panel) → Configuration Wizard (Right panel)
How to set linear evaporation rate:
  1. Open the configuration wizard of the Water Overlay.
  2. Continue to the step concerning weathers.
  3. Select the weather event you wish to update, or select "Add" to create a new one.
  4. Set the "Surface evaporation" setting to "Linear".
  5. In the "Surface evaporation" field, set the desired evaporation rate.
  6. In the "Total rainfall" field, set the amount of rain that should fall during the period of rain.
  7. In the "dry after rain" fields, set the amount of time the simulation should continue after the rain has stopped.
  8. Verify that the total simulation time matches your expectations.
  9. Close the wizard.
The evaporation rate is in mm/day, so for any given evaporation rate configured, the total amount of evaporation will be less as simulation time decreases.
