Ground model (Water Overlay)
File:Underground model.png
The Water Module also contains a simplified 2-layer underground model, for infiltration, evaporation and horizontal flow in the underground. Also simplified exfiltration of water from the soil back onto the surface layer is implemented.
The underground model is only active when the GROUND_WATER attribute of the water overlay to 1 or above. Only groundwater overlays set this attribute to 1 by default. If the underground model is not active, water can not infiltrate, exfiltrate, evaporate or flow in/from the underground.
The underground is bounded vertically by the surface of the terrain at the top and by an assumed impenetrable layer at the bottom. The distance between the surface and the impenetrable layer, and thus the effective height of the underground, is equal to GROUND_BOTTOM_DISTANCE_M. In other words, the impenetrable underground layer is assumed to be a set distance below the surface. The distance is uniform across the entire project area, and therefore follows the profile of the surface.
The groundwater table is the datum height of the top of the saturated zone. The amount of water in the satured zone is determined both the depth of the groundwater table, the GROUND_BOTTOM_DISTANCE_M, and the underground terrain's WATER_STORAGE_PERCENTAGE. Wwhen infiltration and evaporation occur, the groundwater table will fluctuate faster with a lower water storage percentage of the soil.
Initialization
The underground water level is initialized with the values of the ground water GeoTIFF connected to the water model. If no ground water data is connected, the ground water level relative to datum is equal to the surface water level relative to datum, as defined by the WATER_LEVEL attribute of the water level area in that location.
Vertical flow
Vertical underground water flow is modeled as infiltration and described in the subsequent model.
Horizontal flow and aquifers
The underground flow is implemented using formulas described in [1].
  1. ↑ Harbaugh
Cite error: <ref> tag with name "Harbaugh" defined in <references> is not used in prior text.
Template:WaterOverlay nav
