Inlet formula (Water Overlay)
Revision as of 13:08, 15 April 2019 by Frank@tygron.nl (talk | contribs)
Inlets are hydraulic structures can pump water in and out of the project area and are connected with a water body outside the project area.
Inlets:
If a Tl is defined:
Qlth = max( 0 , Tl,t - wt )
If an Inlet q is defined:
Qt = Δt * qt
If a capacity Qtotal is defined:
Qc = Qtotal- Qt-1
After calculating the capacities, the actual water inflow is calculated. If any of the terms are undefined, they are not included.
Δw = max( 0 , min( Qlth , Qt , Qc ) ) / Ai
Outlets:
If a Tlower is defined:
If a IQ is defined:
Cspeed = Δt * IQ
If a Ctotal is defined:
Coutcap = -Ctotal - Cused
Where:
  • cell = Cell size.
  • WLsurface = The water level on the surface, relative to datum.
  • Ctotal = The INLET_CAPACITY attribute of the inlet.
  • IQ = The INLET_Q attribute of the inlet.
  • Tl = The LOWER_THRESHOLD attribute of the inlet.
  • Tu = The UPPER_THRESHOLD attribute of the inlet.
Template:WaterOverlay nav
