Surface model (Water Overlay)
Revision as of 12:00, 11 April 2019 by Frank@tygron.nl (talk | contribs)
The Water Module's primary function is the simulation of the 2-dimensional flow of water on the surface. In order to simulate flowing water, the project area is discretized into x by y cells, based on the configured grid cell size.
Secondly a model is required which describes the rules that need to be followed. For this we use the two-dimensional Saint-Venant system, which reads:
In the Tygron Platform this model is implemented using the Well balanced, positivity preserving central-upwind scheme described in [1] This method rewrite the h from the original Saint-Venant system to w = h + z. See the following image:
Symbol
B surface elevation of grid cell
h water height of grid cell
w water level of grid cell
Surface water level initialization
Template:WaterOverlay nav
  1. Cite error: Invalid <ref> tag; no text was provided for refs named ref-reference
