Surface model (Water Overlay)
Revision as of 11:58, 11 April 2019 by Frank@tygron.nl (talk | contribs)
The Water Module's primary function is the simulation of the 2-dimensional flow of water on the surface. In order to simulate flowing water, the project area is discretized into x by y cells, based on the configured grid cell size.
Secondly a model is required which describes the rules that need to be followed. For this we use the two-dimensional Saint-Venant system, which reads:
File:2D-Saint-Venant system.png
In the Tygron Platform this model is implemented using the Well balanced, positivity preserving central-upwind scheme described in [1]
Symbol
B surface elevation of grid cell
h water height of grid cell
w water level of grid cell
w = h + z
Surface water level initialization
Template:WaterOverlay nav
  1. ↑ Cite error: Invalid <ref> tag; no text was provided for refs named ref-reference
