Surface model (Water Overlay)
The Water Module's primary function is the simulation of the 2-dimensional flow of water on the surface. In order to simulate flowing water, the project area is discretized into x by y cells, based on the configured grid cell size. Next we required a model which contains the rules that need to be adhered. For this we use the Saint-Venant system, which reads: File:2D-Saint-Venant system.png
Terminology
| symbol | |
| B | surface elevation of grid cell |
| h | water height of grid cell |
| w | water level of grid cell |
w = h + z
Surface water level initialization
