Surface model (Water Overlay)
Revision as of 09:23, 11 April 2019 by Frank@tygron.nl (talk | contribs)
The surface is defined by the terrain height in the project. The terrain height is further influenced by the height of constructions present in the project (bounded by DESIGN_FLOOD_ELEVATION_M) and by the BREACH_HEIGHT of breaches.
Surface water level initialization
Template:WaterOverlay nav
