Culvert (Water Overlay)
Culverts are assumed to have a spherical cross-section.
A culvert is a line-based constructions.
Icon Attribute Unit Description Default
CULVERT_DIAMETER m The diameter of the culvert. For throughput calculations, the culvert is assumed to have a spherical cross-section. 1
CULVERT_THRESHOLD m + datum The height of the culvert. (When set to a level lower than the terrain for either endpoint of it, the culvert's height is equal to the height of the (highest) terrain under either endpoint.) 0
Culvert formula Template:WaterOverlay object nav
