Culvert (Water Overlay)
Revision as of 16:06, 3 April 2019 by Frank@tygron.nl (talk | contribs)
Culverts are assumed to have a spherical cross-section.
A culvert is a line-based constructions.
| Icon | Attribute | Unit | Description | Default |
| CULVERT_DIAMETER | m | The diameter of the culvert. For throughput calculations, the culvert is assumed to have a spherical cross-section. | 1 | |
| CULVERT_THRESHOLD | m + datum | The height of the culvert. (When set to a level lower than the terrain for either endpoint of it, the culvert's height is equal to the height of the (highest) terrain under either endpoint.) | 0 | |
