Hydrological attributes of terrains (Water Overlay)
Terrains in a project have a number of hydrological properties which can influence the flow of water in a project. Because there is always both surface and underground terrain defined for the entirety of the project area, all cells are affected by all properties of terrains, unless a construction is present with overwriting values.
Icon Attribute Unit Type Description
WATER_MANNING s/(m1/3) Surface The Gauckler–Manning coefficient of the terrain.
Template:WaterOverlay attribute nav
