Water Overlay
What are the Water Overlays
Configuration wizard
File:Config wizard.JPG
Step 1
Step 2
- ground water data
- Weirs
- Culverts
- Pumps
Step 3
Step 4
Step 5
Step 6
Hydrological features
Water level area
Sewer area
Breach
| SURFACE_OVERRIDE | m + datum | The new terrain height at the location of the breach. | n/a |
| INLET_CAPACITY | m3 | The maximum, total amount of water which can flow in or out through this breach. Water flowing back in the other direction replenishes the capacity. | Infinite |
| LOWER_THRESHOLD | m + datum | If a lower threshold is set, water will only flow into the model through this breach until the average water level on this breach is equal to or greater than the threshold. If the threshold is not set, the amount of water flowing in is not limited in this fashion. | None |
| UPPER_THRESHOLD | m + datum | If an upper threshold is set, water will only flow out the model through this breach until the average water level at the point of this breach is equal to or lower than the threshold. If the threshold is not set, the amount of water flowing out is not limited in this fashion. | None |
Inundation
Hydrological constructions
- Line-based constructions
Culvert
Weir
Pump
| PUMP_SPEED | m3/s | The speed at which water is pumped from the lower water level to the higher water level. | n/a |
Sewer overflow
Inlet
The effects of these constructions can be adjusted by setting the appropriate attributes. In some cases, these are attributes which relate to function values. For these attributes, either can be adjusted to the same effect.
Sewered constructions
Water storage constructions
Porous constructions
Crops and foliage
Critical structures
| CRITICAL_INFRASTRUCTURE | boolean | Critical infrastructure | Whether this construction is deemed a critical construction. |
Chemical emitters/cleaners
Water
Evaporation
Infiltration and storage
Result types
| GPU OVERVIEW | nominal value | Maximum | Shows which GPU cluster calculated which part of the overlay. |
| IMPACTED_BUILDINGS | nominal value | Maximum | Constructions impacted by excess water. Constructions are considered impacted when the construction itself or an adjacent cell contains more water on the surface than configured in IMPACT_FLOOD_TRESHOLD_M. 0: Construction is not impacted |
| UNDERGROUND_LAST_STORAGE | m (mm)¹ | Last | The (effective) amount of water in the underground unsaturated zone at the end of the last calculated timestep. |
| UNDERGROUND_LAST_VALUE | m (mm)¹ | Last | The amount by which the groundwater table has risen above the initial groundwater level at the last calculated timestep. |
| UNDERGROUND_MAX_STORAGE | m (mm)¹ | Maximum | The maximum (effective) amount of water in the underground unsaturated zone across all calculated timesteps. |
| UNDERGROUND_MAX_VALUE | m (mm)¹ | Maximum | The maximum amount by which the groundwater table has risen above the initial groundwater of all the calculated timesteps. |
Result child overlays
Currently, it is only possible to add result child overlays via the configuration wizard.
General Tab
Calculation Preference
Δt = Δx /umax
- Δt = computational timestep
- Δx = grid cell size
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
- Water areas:
Keys tab
| Breach Floor | m + datum | Modified terrain height, to simulate a breach in a levee. |
| Inundation level | m + datum | Initial water height, to simulate water present at the start of the simulation. |
Attributes tab
| MIN_SLOPE | The minimum slope required to account for the effect of gravity on the speed of the water. If the slope of the terrain is less than the minimum slope, the effect of gravity on the speed of the water is assumed to be 0. | |
| SUPERGRID | This marks an experimental feature which is currently under development and may result in unexpected behavior when activated. | |
