Water Overlay
What are the Water Overlays
Configuration wizard
  • ground water data
    • Weirs
    • Culverts
    • Pumps
Hydrological features
Water level area
WATER_LEVEL mNAP The water level for all water terrains in this water level area n/a
Sewer area
Breach
SURFACE_OVERRIDE mNAP The new terrain height at the location of the breach. n/a
INLET_CAPACITY m3 The maximum amount of water which can flow in or out through this breach. Water flowing back in the other direction replenishes the capacity. Infinite
LOWER_THRESHOLD mNAP If a lower threshold is set, water will only flow into the model through this breach until the average water level on this breach is equal to or greater than the threshold. If the threshold is not set, the amount of water flowing in is not limited in this fashion. None
UPPER_THRESHOLD mNAP If an upper threshold is set, water will only flow out the model through this breach until the average water level at the point of this breach is equal to or lower than the threshold. If the threshold is not set, the amount of water flowing out is not limited in this fashion. None
Note that a breach shares attribute names with the inlets, and that changing the attribute keys for breaches also affects the keys for inlets.
Inundation
INUNDATION_LEVEL mNAP The height of the water. n/a
Hydrological constructions
  • Line-based constructions
  • Point-based constructions
Culvert
CULVERT_HEIGHT mNAP The height of the culvert. (When set to a level lower than the terrain for either endpoint of it, the culvert's height is equal to the height of the (highest) terrain under either endpoint.) 0
Weir
WEIR_HEIGHT mNAP The height of the weir. n/a
Pump
Sewer overflow
SEWER_OVERFLOW mNAP The height of the bottom of the sewer, relative to the average terrain height of the connected sewer. Starting from this height, the water level in the sewer must exceed the height of the terrain at the location of the overflow in order for water to flow out. n/a
Inlet
LOWER_THRESHOLD mNAP If a lower threshold is set, water will only flow into the model through this inlet until the water level at the point of this inlet is equal to or greater than the threshold. If the threshold is not set, the amount of water flowing in is not limited in this fashion. None
UPPER_THRESHOLD mNAP If an upper threshold is set, water will only flow out the model through this outlet until the water level at the point of this inlet is equal to or lower than the threshold. If the threshold is not set, the amount of water flowing out is not limited in this fashion. None
Note that an inlet shares attribute names with the breaches, and that changing the attribute keys for inlets also affects the keys for breaches.
Miscellaneous constructions
Besides the constructions which directly influence the main water flow in the hydrological model, there are some constructions which interact with the model in other ways.
The effects of these constructions can be adjusted by setting the appropriate attributes. In some cases, these are attributes which relate to function values. For these attributes, either can be adjusted to the same effect.
In contrast with hydrological constructions and their properties, all constructions can have any or all of the following miscellaneous effects.
Sewered constructions
Water storage constructions
Porous constructions
Crops and foliage
Chemical emitters
Water
Evaporation
Infiltration and storage
Result types
1: Water level area
2: Land
3: Sewer
4: Breach
5: Hydrological construction
1: Construction is impacted, and the critical function value is set to 0.
2: Construction is impacted, and the critical function value is set to 1.
UNDERGROUND_LAST_STORAGE m (mm)¹ Last The (effective) amount of water in the underground unsaturated zone at the end of the last calculated timestep.
UNDERGROUND_LAST_VALUE m (mm)¹ Last The amount by which the groundwater table has risen above the initial groundwater level at the last calculated timestep.
UNDERGROUND_MAX_STORAGE m (mm)¹ Maximum The maximum (effective) amount of water in the underground unsaturated zone across all calculated timesteps.
UNDERGROUND_MAX_VALUE m (mm)¹ Maximum The maximum amount by which the groundwater table has risen above the initial groundwater of all the calculated timesteps.
Result child overlays
Currently, it is only possible to add result child overlays via the configuration wizard.
General Tab
Calculation Preference
Δt = Δx /umax
  • Δt = computational timestep
  • Δx = grid cell size
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
  • Water areas:
Keys tab
Breach Floor mNAP Modified terrain height, to simulate a breach in a levee.
Inundation level mNAP Initial water height, to simulate water present at the start of the simulation.
Attributes tab
AVG_SURFACE_WATER Description wil be added
MIN_SLOPE slope whereunder the pressure slope is assumed 0
SEWER_OVERFLOW_THRESHOLD fraction of storage whereafter sewer overflows take place
SHOW_DURATION_FLOOD_LEVEL_M m threshold value of the amount of water on a grid cell that is used for the SURFACE_DURATION result type
SUPERGRID This marks an experimental feature which is currently under development and may result in unexpected behavior when activated.
SURFACE_WATER_EVAPORATION_FACTOR Description wil be added
TIMEFRAMES the number of intermediate (overlay) results you would like to see of the calculation. A timeframe is not the same as a timestep. A timeframe is an intermediate (overlay) result and can contain already a number of timesteps. The number of timesteps is based on the grid cell size and the speed of the flooding (see for more information the Courant number).
